complete Mivec 6a12 engine FS- In parts
fto-007
Post by fto-007 »
Hi guys i have a complete MIVEC 6a12 engine for sale. The exhaust cam has locked solid causing the cam to lock, snapping the cam gear pin and throwing the cam timing out causing it to stall. I have ordered another engine and selling off the parts off this one. Parts for sale are. I have pulled the heads off as i was unsure if pistons hit the valves, so the bottom end is fine with 180,000 odd Kms. So prity much im keeping one complete head, starter motor, alternator everything else is for sale.
*Side covers, harmonic balancer
*injectors, rail, FPR
* Plenum ,TB, sensors
*Pistons, rods, crank, block (not damaged)
*one complete head (pulled down)
can post pic if requested
FTOwnage
Re: complete Mivec 6a12 engine FS- In parts
Post by FTOwnage »
Dibs engine cover/plenum.
Can you post?
fto-007
Post by fto-007 »
Hey mate is can post them did you want the throttle body and sensors? Where are you located
FTOwnage
Post by FTOwnage »
May as well take them too.
Located in Warners Bay 2282 NSW
fto-007
Post by fto-007 »
ok sweet how does 150 delivered for the two sound?
fto-007
Post by fto-007 »
Sold- MIVEC cover
All other items are available and going CHEAP
Mitsiman
Approved FTO Australia Trader
Post by Mitsiman »
Do you still have the damaged cylinder heads? I need a sample head as long as it has valves and a undamaged combustion chamber.
Please let me know if you do - happy to organise freight from this end (Perth)
fto-007
Post by fto-007 »
Hi I only have the rear head as the front was damaged and I binned it
Mitsiman
Post by Mitsiman »
What do you want for the one cylinder head then - not much of a market for a single cylinder head :) Give me a call or I can call you if you wish.
I'll take the cam belt covers
silverphoenix
Post by silverphoenix »
Hey 007,
Still got the starter motor?
