Fans not always working
- Cassf88
Re: Fans not always working
CLUSTER!!!
Changed the ECU, fans still not working.
c**nts fucked.
c**nts fucked.
- rock_it
Cluster?Daniel2019 wrote:Changed the ECU, fans still not working.
c**nts fucked.
rock_it wrote:Cluster?Daniel2019 wrote:Changed the ECU, fans still not working.
c**nts fucked.
Did u try cluster
I'm going to lock this until such time as you go see a qualified auto electrician to get this fixed, you tight arse!
I'm not a tight arse, I'm a stubborn c**t who refuses to be beaten by an overheating car.Bennoz wrote:I'm going to lock this until such time as you go see a qualified auto electrician to get this fixed, you tight arse!
But me thinks I will have to get someone else to look at it
You're a tightarseDaniel2019 wrote:I'm not a tight arse, I'm a stubborn c**t who refuses to be beaten by an overheating car.Bennoz wrote:I'm going to lock this until such time as you go see a qualified auto electrician to get this fixed, you tight arse!
- rock_it
Did you try the fan test like Phill suggested..?
Can't remember..
Can't remember..
Yep.rock_it wrote:Did you try the fan test like Phill suggested..?
Can't remember..
- rock_it
And they came on??
I believe they came on just from unpluging the sensor harness.rock_it wrote:And they came on??
He didn't bridge the connections of the harness.
Correct.PHIL069 wrote:I believe they came on just from unpluging the sensor harness.rock_it wrote:And they came on??
f**k it i'll just have to take it to an auto elec tomorrow.
Putting money down for the most simplest oversight in automotive history.
I'll have a piece of that wager!Astron_Boy wrote:Putting money down for the most simplest oversight in automotive history.
Should it make a difference? Do we have some sort of 'safe mode' when no signal from the coolant sensor is given, that the fans kick in constant?PHIL069 wrote:I believe they came on just from unpluging the sensor harness.rock_it wrote:And they came on??
hahahahahaha cant wait!
- rock_it
ClusterDaniel2019 wrote:Astron_Boy wrote:Putting money down for the most simplest oversight in automotive history.
It's not the fkn clusterrock_it wrote:ClusterDaniel2019 wrote:Astron_Boy wrote:Putting money down for the most simplest oversight in automotive history.
