Hey guys.
So I picked up a brushed metal dash plate for around my dials and I'd like to convert the dial backgrounds to white, I don't mind if its a glow kit or what not, but I'd rather not have to pull the needles off as last time I did that on my prelude I had a needle that would show I was doing 260kmh when I started accelerating (or it was the fasted prelude in the world)
I looked on eBay all I see is mph or kmh but it's just a face plate that uses the old bulbs to light it up, and well my dash lights aren't what you call bright.
So what would you guys recommend? Have any of you installed the non light up slip on dial kits that require the needle to be taken off?
Cheers
White Dials - Where to buy
- JAMZO_wamZo
Hey. Hey fella..
- kiz
- SA Coordinator
Re: White Dials - Where to buy
I've got EL dials on mine, they just slip over top and easy to wire in.
Here's one to consider;
http://www.nengun.com/unknown/unused-ft ... ite-352278
Works out to about $100aud for the EL dials not matter which brand you get
1998 Mitsubishi FTO GPVR AERO
- JAMZO_wamZo
You sir, are a champion. yeah that is exactly what i was looking for.
Thanks!
Thanks!
Hey. Hey fella..
- kiz
- SA Coordinator
Yea I was going to get them but I've become accustomed to my carbon fibre ones nowJAMZO_wamZo wrote:You sir, are a champion. yeah that is exactly what i was looking for.
Thanks!
Just quickly, make sure youre getting the proper one! As in manual or auto. Otherwise your RPM will be off and you will have either auto lights that do nothing or no lights in your auto.
- JAMZO_wamZo
Thanks for this, i sent them an email to ask which version, if i get a reply or not we'll soon see.Daniel2019 wrote:Just quickly, make sure youre getting the proper one! As in manual or auto. Otherwise your RPM will be off and you will have either auto lights that do nothing or no lights in your auto.
Hey. Hey fella..
- Corey95
This probably explains why my tacho reads 3500 rpm at 90 k's and 4000rpm at 100k'sDaniel2019 wrote:Just quickly, make sure youre getting the proper one! As in manual or auto. Otherwise your RPM will be off and you will have either auto lights that do nothing or no lights in your auto.
- bjk
- Totes
In which gear?Corey95 wrote:This probably explains why my tacho reads 3500 rpm at 90 k's and 4000rpm at 100k'sDaniel2019 wrote:Just quickly, make sure youre getting the proper one! As in manual or auto. Otherwise your RPM will be off and you will have either auto lights that do nothing or no lights in your auto.
- Corey95
In 5th of coursebjk wrote:In which gear?Corey95 wrote:This probably explains why my tacho reads 3500 rpm at 90 k's and 4000rpm at 100k'sDaniel2019 wrote:Just quickly, make sure youre getting the proper one! As in manual or auto. Otherwise your RPM will be off and you will have either auto lights that do nothing or no lights in your auto.
