Soldering Kit
Soldering Kit
Does anyone have a soldering kit that I could borrow for like 20 minutes around the eastern suburbs area?
Need to solder my speaker wires :D
Re: Soldering Kit
Daniel2019 wrote:Does anyone have a soldering kit that I could borrow for like 20 minutes around the eastern suburbs area?
Just double checking, you do know that a soldering iron & solder can be obtained from Bunnings for less than 20 bucks yeah? A worthy addition to any n00bs toolkit!
Re: Soldering Kit
Some pretty good ones on the market place nowadays....
Re: Soldering Kit
We have one at home from when pop used to have to fix up his horse and cart but the blowtorch wouldnt heat up the iron properly :lol: :troll:
Didnt know they were as little as $20, might have a trundle down to bunnings this afternoon in that case! :cheers:
Cheers Bennoz ;)
Re: Soldering Kit
The most important thing to remember when soldering is keep your tip clean. Wipe it on a wet sponge each time you pick it up to solder something.
Re: Soldering Kit
Vectose wrote:The most important thing to remember when soldering is keep your tip clean. Wipe it on a wet sponge each time you pick it up to solder something.
Wow, my mind went straight to the gutter when I read that. Of course it did replace a few words :lol:
Re: Soldering Kit
Yeah I learnt that in DT. Ive done a bit of soldering here and there so yeah ;)
Re: Soldering Kit
I just scrape it on the concrete, yolo.
Re: Soldering Kit
silverGPX wrote:I just scrape it on the concrete, yolo.
Pop nearly set our lawn on fire because the torch was fucked :lol:
Re: Soldering Kit
i use a lighter and fart on it
