FS!! Fto turbo kit $1600
- fto-007
Hi all up for sale is my turbo setup. It comes with headers, y pipe, turbo feed, dump pipe too cat also comes with 560cc injectors (low independence) with fuel pressure regulator. Turbo is a garrett 2860r (may need re-build not sure). Will put up pic soon
- Shane001
Re: for sale!! Fto turbo manifold/ turbo / injectors, fpr
fto-007 wrote:(low independence)
- fto-007
low impedance injector can mechanically react quicker to an injection pulse signal, but requires drivers capable of a larger current draw(your ECU).
It's more of a technical aspect. performance wise you would notice the difference. But wire low impedance injectors to a ecu designed for high impedance injectors, with out a drop resistors, and you could count the seconds before you let the smoke out. but you knew that
look again what you typed
im assuming thats what he is laughing at
- Shane001
- fto-007
- Shane001
So how much are you looking for out of curiosity?
Is everything included for a "bolt on" setup or are more mods required?
Might get a few bites if people know what they are up for (ex. Labour costs)
If I didnt just purchase anither fto I would consider this lol
- fto-007
the turbo is off a 6a12 mivec manual. It would still bolt on a non-mivec it has 2.5" feed and dump pipe It has modified rpw headers. It comes with water lines no turbo oil feed or return.Im running a full stand alone Wolf v500 Injectors will requre a stand alone ecu with larger fuel pump the turbo that was on it was never boosted over 12psi. No need for 560cc injectors anymore as i will need bigger.
To finish off the turbo you will need
*fuel pump
*stand alone ecu
*intercooler / piping
*turbo oil feed / return
*cat converter may need re-positioned?
*fuel pump
*stand alone ecu
- Dras
Wow, $1500 is a good price. Very tempting.
Do you need to remove the AC to make this fit?
- rock_it
Hmmmm ... Dare I????
- fto-007
Na you dont have to remove the ac and you can have the abs aswell
This kit made 228hp at the wheels
- fto-007
sorry about the words in the pic had to make pic smaller
- 2012-01-12 18.36.11.jpg (20.06 KiB) Viewed 567 times
- 2012-01-12 18.36.29.jpg (21.53 KiB) Viewed 567 times
- Kustom
- fto-007
Not sure yet have to see if the engine is ok. . If not i will do a mivec 6a13
- FTO430
So tempting...
Supercharger or turbocharger.....
OR BOTH!
OR BOTH!
[img]http://www.mitsubishiclubaustralia.com/forums/garage.php?mode=view_gallery_item&type=garage_mod&image_id=1654[/img]
- fto-007
i come up with the same delamere turbo was easyer i say and you would supercharge one for the price of this turbo kit lol
- fto-007
listed in turbo fto
viewtopic.php?f=22&t=25855
- SchumieFan
would you really need to upgrade the fuel pump?????
- fto-007
You could get away without doing it...but I wouldn't like it to lean out..
