i have a full gpx auto box, with torque converter and all sensors (plus have 2 more input and output sensors for those with the facelift/3wire inputs). just a standard diff (dont know if its 27 or 25 spline, il count later on). i bought it 6 months ago off japan auto parts in brissy for $1300 ($1200 + 99 postage). it was for when my auto stuffed up, thought i could do a straight swap with my gpvr, turns out there are differences, like tranny mounts and something is missing/extra between the 2 auto boxes, transmission guys tried to chuck it in, but i had too little/many wires in my gpvr to make it work, and they could only get it to work in limp mode (said that its obviously a sensor mismatch problem), so i just bought a manual.
i don't know how many ks, they said very low k's :s, hence why it cost me so much,
im looking at $600, half what i bought it for and i have not driven with it. so a bargain. i couldnt return it as i kept it until my manual was installed (in case the manual wouldnt go in, then i would have just bought the wiring harness and ecu to suit the auto, so it was past its 3 month warranty.
preferred pick-up, i can go out to Melbourne or Ballarat, but will send at your expense
call on 0431028172 if you have any more questions
jade
auto transmission
- millsy
- Nacho
Re: auto transmission
Do you still have your receipt from where you bought the box from? Will need it for VIV most likely so if you do I may consider it.
- millsy
i have some photos of the receipt that came with the transmission, and i have the website, email and confirmation of payment email i sent, but no other paperwork on their behalf, except the photos of the receipt. in good enough detail for you to claim stuff on a viv except its all in my name and address. u can email them if u like them to print out a copy i guess
- Nacho
A photo of the receipt? What a weird thing to have!
Can you please PM me this photo so I can have a look? I still gotta find a way to move the thing if I decide to buy it
auto transmission
They aren't too heavy, just get a Sudanese to walk with it on their head for you.
- HeRo
That is very interesting, because I had the same problem. I chucked in a GPX 4spd tranny into my GPvR and it only works in limp mode. The N flashes and gets stuck in 2 and 3, otherwise if i pull the speed sensor out i get no working speedometer.
Are you absolutely sure you cant change the speed sensors around the work with the car? Or is my only option to buy a GPvR gearbox and chuck it in ?
any help is appreciated!
- millsy
I changed the sensors to suit my plugs, i had a 5 speed tip originally, and chuked in a 5speed tip off a gpx, not sure if there is just a simple way out of it, i could have paid some auto gearbox/electricians to check it out, but took the option of converting it to manual for the same price, so it may have just been a case of switching around 2 wires on the harness, but il never know, guessing its bound to work with a ecu/harness change obviously. But my speedo was working and rpm, was just in limp mode
- HeRo
yeah the speedo and tacho work if its plugged in, but as you said, its in limp mode with a code that one of the threads state is a speed sensor mismatch.
what i'm sayin was it can run all 4 gears if i unplug the speed sensor. Any chance I can buy an input and output speed sensor off you to test?
