EOI: New exhaust collector pipe
Hey guys,
When my car is finished off in the next week or 2, I'll be dropping Kaz's GPX down to have a new exhaust put on. In doing so we are going to make a new collector pipe - from the headers to the cat. As we all know the standard collector pipe is very restrictive & the 2 banks join in somewhat of a collision point.
Now UAS have a product like this (pictured below) but @ $700 its not really the best bang for buck...
When we make one up for Kaz's car, if there is enough interest, i'll make a jig for it so we can churn out a number of these things at a reasonable price. We are also looking to do a deal where you can buy both the pipe & high flow steel cat to suit.
On its own, the pipe gives 4-5 atwkw gain, couple that with a high flow cat, you're looking at 10-12atwks. Its the best bang for buck exhaust mod you can do, short of replacing the whole system. I'll be doing dyno test results with Kaz's car.
It will be a direct bolt on fit for a GPX, and will only require a flange modification to suit a GR.
If you already have RPW extractors, then they wont be of use to you as they come with a good collector pipe.
So, if you are interested, let me know! I've not got prices yet & wont until we make one, but I'd say it'll be around the $400 mark.
- Valandis91
so your saying the RPW collecter pipe which has the the sweeping bend from the headers to the normal pipe (you know what i mean?) is as good as the UAS one or similar?
the UAS one looks a lot smoother and higher flowing than the RPW cos the rear collector has to do a 180 degree turn with the RPW one..
- Valandis91
- aza013
- NSW Coordinator
- Jamie
- FTO_GPvR
Hi club,
sorry to sound noob but im confused, i dont this, can you help me out thanks
alright
with the exhaust does it start from the headers to the extractors to downpipe to pipe to catback lol i reckon its all wrong what i just wrote, i need help lol
so from where does it start from to when does it finish
because people on this club have a 3inch exhaust all the way whats that
again sorry for any trouble
thanks club
alright
thanks club
Headers-collector-cat-mufler-pipe-muffler-tip.FTO_GPvR wrote:Hi club,
alright
thanks club
Not every car is the same, but for the FTO that's how it is.
This replacement part being the collector.
Hope that helps you.
- FTO_GPvR
ok mate your a champAstron_Boy wrote:Headers-collector-cat-mufler-pipe-muffler-tip.FTO_GPvR wrote:Hi club,
alright
thanks club
thats cleared things up
so with all this Headers-collector-cat-mufler-pipe-muffler-tip u can get 3inch for all of these and it would be a 3inch all the way exhaust system is that right?
howcome theres 2 mufflers in the list?
and also what about the extractors there not there in the list?
cheers,
Tyson
-EDIT DONE-
3 inch is too big for the FTO, you'll loose back pressure & therefore power if you make the entire system from 3 inch. Standard FTO size is 2.25 inch, the best upgrade size is 2.5 inch. You can have whatever tip size you like, it makes no difference to performance.
The first muffler is actually a resonator. It helps quieten the noise down.
There are no extractors involved in this, its simply a 2.25 inch stock collector pipe replacement. Its bolts directly to the FTO cast iron headers & cat.
- FTO_GPvR
Ok thanks Ben for the infoBennoz wrote:3 inch is too big for the FTO, you'll loose back pressure & therefore power if you make the entire system from 3 inch. Standard FTO size is 2.25 inch, the best upgrade size is 2.5 inch. You can have whatever tip size you like, it makes no difference to performance.
I might be interested in it
- aza013
- NSW Coordinator
- alekazam
- aza013
- NSW Coordinator
- koolio1234
