Bennoz 6A13 Conversion
- spetz
Re: Bennoz 6A13 Conversion
How much punishment does the gearbox get?
And, when you take the gearbox out, do you support the motor with something?
How do you lift the gearbox back into place?
I don't flog it hard, the damage is done by the odd heavy take off. The bearings just can't handle the torque load. The gear cluster itself & the syncros are fine. I can't remember what my torque figure was, but it was something like 450 odd Nm.spetz wrote:How much punishment does the gearbox get?
Yeah I leave the jack under the motor. I just lower it down on the passenger side to slide the box on & off. I leave the timing belt end mount connected as a pivot point.
Depending on whether I've got the communal engine hoist at home, I can use that to lift it into place, otherwise I just hand lift it in with the aid of another jack. They're not that heavy.
- spetz
I remember you said it was 50kg which is still quite heavy.
Does someone help you?
Yeah, a guy called Jack. He can usually lift about 1500-2500kgspetz wrote:I remember you said it was 50kg which is still quite heavy.
- spetz
Jack sounds really helpful
- Shhtuart
I'm a pretty skinny guy and I managed to lift a manual gearbox out my boot, up the driveway and I to my bedroom in one go. They are a fair chunk of metal but it is manageable with one person.spetz wrote:I remember you said it was 50kg which is still quite heavy.
Forgive my mind slipping... much like your gearbox.
But how is it the Legnum/ Galants boxes can withstand the punishment but the FTO box can't?
I know of a few worked Legnums pushing some decent figures, and even then the gearboxes with-hold.
It can't simply be the factor of a transfer case....?
Bennoz is a hoon
- spetz
Yes moving it around wouldn't be a problem but I was interested in the removal and installation part considering the awkward position Bennoz would be in (no innuendo intended) and the danger of it falling etcShhtuart wrote:I'm a pretty skinny guy and I managed to lift a manual gearbox out my boot, up the driveway and I to my bedroom in one go. They are a fair chunk of metal but it is manageable with one person.spetz wrote:I remember you said it was 50kg which is still quite heavy.
I'm not the only one with this problem mate.Astron_Boy wrote:Forgive my mind slipping... much like your gearbox.
Google Evo or legnum gearbox input bearing...
http://forums.evolutionm.net/evo-engine ... hread.html
Look familiar? That's an Evo box.
- fraz91
- Hair-do
Stand back people, he's had a brain fart
f**ken LOL!fraz91 wrote:Stand back people, he's had a brain fart
We know where some of Bens money will be going soon.
fair enough, just don't hear of it as often, but I'm not primarily on those forums...Bennoz wrote:I'm not the only one with this problem mate.
So when I get my Wavetrac, should i get the synchros, bearing kit, and this upgraded bearing you just linked us?
Totally, im surprised you gearbox can handle all that raw power youre putting through it on a daily basis...(when it is actually fixed and in working order)silverGPX wrote:So when I get my Wavetrac, should i get the synchros, bearing kit, and this upgraded bearing you just linked us?
K, honestly, getting a bit tiresome, and I swear to god I will vice grip your balls at the bonfire if you don't simply drop it now.Taz wrote:Totally, im surprised you gearbox can handle all that raw power youre putting through it on a daily basis...(when it is actually fixed and in working order)silverGPX wrote:So when I get my Wavetrac, should i get the synchros, bearing kit, and this upgraded bearing you just linked us?
And I aim this at all the kiddies involved with this bullshit of a keyboard tantrum.
EFA.Astron_Boy wrote:K, honestly, getting a bit tiresome, and I swear to god I will vice grip your balls with my mouth at the bonfire if you don't simply drop it now.Taz wrote:Totally, im surprised you gearbox can handle all that raw power youre putting through it on a daily basis...(when it is actually fixed and in working order)silverGPX wrote:So when I get my Wavetrac, should i get the synchros, bearing kit, and this upgraded bearing you just linked us?
But in all seriousness, +1 to that (minus the testicle related part)
Well maybe count me into the bonfire if Dan is going to grip my balls with his mouth
- spetz
This will fit the FTO box?
that's cuteShhtuart wrote:I'm a pretty skinny guy and I managed to lift a manual gearbox out my boot, up the driveway and I to my bedroom in one go. They are a fair chunk of metal but it is manageable with one person.spetz wrote:I remember you said it was 50kg which is still quite heavy.
