Bennoz 6A13 Conversion
Re: Bennoz 6A13 Conversion
waw
this is minted
always loved the 6a13tt engine
so whats the next thing you have planned?
this is minted
Slow & steady progress with my little belt grinder! Just a couple more mm around the top right.
- mattman
you should grab a die grinder there cheap as it would get the job done a lot quicker as
FTO ftw
I did and it didn't.mattman wrote:you should grab a die grinder there cheap as it would get the job done a lot quicker as
Having said that, the tip selection at Bunnings wasn't the best
All done now anyways
Amazing really how much 5mm does make a difference when you compare the two.
Be interesting to see the end results.
You have a current/ 'before' dyno graph at all Bennoz for comparison?
- spetz
How will you clean the intake manifold to make sure no debris is left behind?
Just chuck it in the parts washer as per usual, it'll clean out ok.
Unfortunately I wont be able to give accurate before & afters because I'm doing other things to the car that will effect power readings as well. I'll be able to give a ballpark figure though.
As much as I'd like to give you all a before & after for every mod, everytime its hits the dyno, its $140 regardless of whether its on for 10 minutes or an hour. Then its $140/hr after that lol.
Hey,
are you able to upload some overall pics of your engine bay and car in general.
I've been looking through the thread and noticed only a few...
Yeah, fair enough.
Not like everyones asking for it, and you've offered to be a dedicated testing piggy.
- aza013
- NSW Coordinator
I'm getting bared up looking at these pics and thinking about all the KWs that it will give .
Or I should not watch porn when reading the forum .
- Kustom
Looks good ben, Looking forward to seeing the results.
How the hell can you multi task?aza013 wrote:Or I should not watch porn when reading the forum .
Something you're not telling us Aza?
Whoops, did an fto aus in the thread.
- aza013
- NSW Coordinator
if you can rub your belly with one hand an tap the top of your head ( above your shoulders lol) with the other hand, then you can do anything .Astron_Boy wrote:How the hell can you multi task?aza013 wrote:Or I should not watch porn when reading the forum .
Now we best get back on topic .
- rock_it
Astron_Boy wrote:Amazing really how much 5mm does make a difference when you compare the two.
- SchumieFan
ROOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOR
this page rocks this thread!
you f**kers make me laugh!
All done
Just gotta bolt it up tomorrow
Looks the goods
nice nice.
- ObsidianRadio
/licks
- spetz
Is that a box to a Tamiya M-01??
