Daily Tiptronic driver
- XXXFTO
Hi ellusion
When turning a corner you slow down, thus your revs drop also and the auto compensates for this by dropping a gear to keeps the revs hi enough.
If the INVECS II is in 4th gear and your speed goes under about 42km and 2000rpm then it will drop to 3rd gear. You can downshift a few seconds before you hit the corner to slow yourself down if you wont but i dont bother. I never down shift to slow down, only to overtake.
It is the same as if you were in a manual, u must downshift when slowing down or else you will stall, no one takes a decent corner in 4th in a manual. when you drop a gear it is also better for acceleration coming out of the corner.
All autos go up or down the gears when need you just cant tell as much because there are no lights on the dash to say which gear it is in (except for tip)
Same with going up a gear. 1st & 2nd can be used from a stand still. 3rd will not kick in until at least 25km maybe more and also 4th wont until about 42km.
- ellusion
Basically i should downshift before turning the corner right. This way, i'll be downshifting before the gear gets a chance to do it itself. Do you just let go of accel and then change gears or do you brake a little bit before downshifting??
I've only just got this car and not sure how to use it properly (the tip).
Sometimes when i wanna downshift from 3 to 2, i will pull the gear stick. However, since the gear box also downshifts i end up downshifting twice to gear 1 which jerks the whole car. Whats wrong?
- XXXFTO
The only advantage of downshifting before you hit the corner is to slow you down. I let it change down itself to so there is less stress on the auto.
If you dont let go of the accel before you drop down a gear then the car will not slow down, it will go a little faster. There is no point in dropping down a gear and breaking at the same time. You may as well just break normally and let it go to 3rd automatically (this will happen in tip mode)
If you have only just got the car then practice working up the gears before you start to religiously using it to down shift. I always have the car in tip mode but never down shift unless i over take (as i said before)
It is important not to drop to 1st at all as this will cause a lot of stress
Even manuals never drop to 1st
damn what a quick reply
yeah i wasnt recommending it either... but just making the point that it is possible.
i used to drop down to first all the time in my tip, how are you gonna stop it from dropping into first where... say you are are going about 20-30kph, and you have it in D, if you kickdown on the accelerator (overtaking, or out of corners) guess what's gonna happen... i guess mitsubbishi should have programed INVECS II so that it doesnt do that on kickdown... what a shame...
say you have it in tip mode, and you wanna overtake someone in the same situation, are you gonna try that in 2nd gear? good luck.
ellusion, in terms of trying to get it to 2nd around a corner, just move to tip mode manually well before the turn, start braking... then drop it down from 4 to 3, then as you drop more speed, go from 3 to 2 just before you enter the turn. now you can complete your turn in 2nd without it going into 1st inadvertently.
- XXXFTO
- rxboy
In my 5-speed tip, when I'm making a right-angle corner at the recommended 20-25km/h speed, the car stays in 3rd unless I downshift it in tip mode. It won't drop to 2nd and subsequently 1st until I come to a stop or close to it (up to 5 km/h).
So, once I brake enough to make the turn, I just downshift to 2nd and have enough revs to exit faster.
- kazbah
- National Secretary
- GPXXX
yeah man, i finished TAFE there as well and then gaduated from Bach. Comp Sci back in '97 LOL... it sure has changed a lot since then! thank GOD it's all behind me now...Oragami wrote: Hey GPXXX...U r a ex-Swiny 2? When did u finished??? I always drop by @ Swinburne every now and then cos my current uni is in Toorak
...which course were you from?
Alright here's one for ya. Picked up my GPX on Sat and now after giving tip a go I'm scared to downshift.
Not matter what speed I'm doing, or how many gears I go down I'm getting jolts thru the car (not a nice feeling I tell ya). BUT if I'm driving in normal auto it downs gears as smooth as silk.
Also, my tacho looks like it's from a manual. There are no bloody gear indicators on it!
Sounds like a good excuse to get a set of aftermarket ones mate!TheSentry wrote:Alright here's one for ya. Picked up my GPX on Sat and now after giving tip a go I'm scared to downshift.
- MattG
Maybe he can't see the gear indicators becaue he HAS got some aftermarket dial faces?
Some of the aftermarket ones don't include any markings for the tiptronic gears - also there are two types, one for 4speed auto and one for 5 speed auto.
What colour are you dial faces?
M@
M@
The Data Recovery Experts
They're the standard black (or is it a dark grey?). Any way they look like the stock ones, cept for the fact that there r no gear indicators. The tacho covers most of the circle, just like the one on the manual. It doesn't fill 3/4s of it and have the gear indicators underneath that like the other tips I've seen. Very odd.MattG wrote:What colour are you dial faces?
