N gear flashing
Re: N gear flashing
Don't need to take the clips off
Re: N gear flashing
Sahin wrote:Don't need to take the clips off
Yeah, was about to say. The bracket bolts are easy to get to on the auto, compared to the manual. haha.
silverx
Re: N gear flashing
Post by silverx »
Sahin wrote:I changed one of them today and it took 5 minutes
Undo the two bolts holding down the selector cable bracket and push it aside to get to the input shaft sensor bolt
Hi sahin do you have to remove air filter box (the big black plastic box) to remove the two bolts?
Re: N gear flashing
Only the top half
silverx
Re: N gear flashing
Post by silverx »
Where are these 2 bolts located? Are they the ones in front of transmission oil filter?
Re: N gear flashing
Right above the sensor and one is partly obstructed by a little bit of the gearbox mount
silverx
Re: N gear flashing
Post by silverx »
Sahin wrote:Only the top half
Sorry to be asking a lot but any chance getting the picture of the location of these 2 bolts? Cheers
Re: N gear flashing
I don't have a photo but you'll see them it holds down the selector cable (the cable that goes across the sensor you're trying to move)
silverx
Re: N gear flashing
Post by silverx »
Are the bolts in here?
Re: N gear flashing
That's the selector there's two bolts that bolt that whole bracket down
silverx
Re: N gear flashing
Post by silverx »
Sahin wrote:That's the selector there's two bolts that bolt that whole bracket down
Close to the air filter box or at the back? I will double check it this evening
Re: N gear flashing
Oh yeah I was thinking manual for some reason :scratch:
Don't listen to me... not like anyone ever does anyway
silverx
Re: N gear flashing
Post by silverx »
Merry Christmas everyone
Managed to remove the bolt that was holding the selector cable
I was struggling to get any tools in there let alone able to undo the nut
Will try again tomorrow as the sun was coming down and i couldn't really see a thing
silverx
Re: N gear flashing
Post by silverx »
Managed to get the sensor out. Wipe it and put it back on and now the issue seems to be fixed :D
Cheers guys
Re: N gear flashing
Get a new sensor itll stuff up again and they're only $50 brand new
silverx
Re: N gear flashing
Post by silverx »
Sahin wrote:Get a new sensor itll stuff up again and they're only $50 brand new
Sure enough it stuff up again. Where did you get it for 50 dollar? I was quoted 110 from local mechanic shop. He needs to order it from sydney
Re: N gear flashing
Amayama.com
silverx
Re: N gear flashing
Post by silverx »
Sahin wrote:Amayama.com
Thank you mate. I noticed that site mentioned couple of times but it escaped my mind when i was looking for the sensor
I couldn't find part number everywhere i search as i used the psrt number from this page http://www.camskill.co.uk/m3b17s12p7076 ... p_to_09_95 but in amayama i end up getting 2 parts for the same number. One with md prefix one without. I am not sure which one is the right sensor.
Cheers
Re: N gear flashing
What year model is yours?
silverx
Re: N gear flashing
Post by silverx »
Sahin wrote:What year model is yours?
94 gpx mate, the 4 pin up to 95 triptonic
