The Suspension Thread
- Doobs
Re: The Suspension Thread
Are they droplinks Az?
Or actual arms.
Or actual arms.
- aza013
- NSW Coordinator
They are the arms
- Doobs
Not too bad for the money.
Paid $200 for a cheap set for my sky.line.
Those look a lot better.
- Dan25
Very interested...aza013 wrote:Just got a price on these they are at this time $300 + postage or free pickup.
I will see if I can get a better price for a GB.
BUT the big thing is to see if they fit and work on the FTO's befor any one gets them
Btw, I noticed Ben called them trailing arms, but aren't they bottom arms?
- Dan25
Re:
My facelift GPX already has these arms on it. My car was stock as a rock when I bought it, and they certainly don't look anywhere near new so I'd say it's pretty much guaranteed they've been on there since manufacture.Bennoz wrote:Here's the EVO arm:
- vipfto
I bet yours dont have the re-enforcement on them though
all FTO's will have them though
- Dan25
LOL! That's what I'm saying, they do have the reinforcement. I'll take a pic if you like
- zuihoujueding
Re: Re:
+1 on that.Dan25 wrote:My facelift GPX already has these arms on it. My car was stock as a rock when I bought it, and they certainly don't look anywhere near new so I'd say it's pretty much guaranteed they've been on there since manufacture.Bennoz wrote:Here's the EVO arm:
- Dan25
Must be a facelift thing
- zuihoujueding
yes. mine is a 97 facelift gpx
- Gholdwayne
Ok so i'll be putting BC BRgold coilovers on the fto soon, just a quick question, i was looking at having -1 camber front and rear. now is that setting ok ? plus i might want/need some tips on what else to do or how ever else to setup the coilovers here and there..
The car's dominant use is in the streets with rare tracking fiy...
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
FTO[For The Orgasm]
- Gholdwayne
Got my BC BR's installed now, sent the car to get a wheel alignment from bob janes close to my work for $69 (freakin rip when i can get it done for 45 at ozzytyres, but i want to get it done asap)
requested to get street specs plus -1 of camber all round. will post pics later on.. in life
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- zuihoujueding
which ozzytyres u go to?
- Gholdwayne
st marys nsw
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- iced
Gholdwayne wrote:Got my BC BR's installed now, sent the car to get a wheel alignment from bob janes close to my work for $69 (freakin rip when i can get it done for 45 at ozzytyres, but i want to get it done asap)
Post a review to show how good these are
These rock.
Absorbs bumps very nice and the grip is very nice even before a wheel alignment.
Car hasnt met corners like that until it met me
Hope you are happy with them.
Making Mitsus fast is fun.
Did you get an alignment yet?
The alignment place I referred you to is real good but if its too far make sure you can confirm the alignment specs on paper printout or the machine display.
- mr-charisma
yep, give us a proper review incl spec on your setup config etc
- pete_gpx
I'm running the BC BR series coilovers on my FTO at the moment. I'm loving them. They're being used them in conjunction with a set of front and rear Cusco strut braces and Mitsubishi GTO front brakes. I have had a basic wheel alignment performed at Bridgestone, however I'm yet to take it anywhere to dial in any serious camber or toe in to see the cars true handling potential.
- Gholdwayne
ah sorry guys, i have been meaning to post the photos and all but i really want to do so after i wash the car, then i will write up my thoughts on the bc's ok? ok...
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- Gholdwayne
iced wrote:Car hasnt met corners like that until it met me
Or maybe it has, with me, only i have never experienced it passenger-perspective-wise until that day ... you're a good driver man , rev matching and heel toeing was excellent;)
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- vipfto
Ok Im running them with front and rear bracing incl good 17inch rubber
Currently have -2 degree camber front with -1mm toe out
-1 degree rear with 0 toe
I do have extra castor bushes in control arms too with damper set to 20 all round when hard driving but for usual city running have them set to 5
Would not reccomend my settings for daily driving though and would give less front camber and 1mm toe in
Find them not too harsh if set to softer levels but can be very bouncy when set harder
also with current setup tends to follow any change in road surface but would reccomend them 100%.
I have changed spring length slightly so to not be so tightly bound for little extra comfort and travel
HTH
HTH
