Toby's nut
Re: Toby's nut
This is crazy f**ked up, even for you Toby
I would say you tried to move both nuts together.
The top red nut is the adjuster, the bottom red nut is the lock nut.
You have to seperate/loosen the lock nut and then moove the adjuster nut, then tighten the lock nut back onto the adjuster nut.....you nut
Re: Toby's nut
Exactly. Quite clear in the BC instructions to not touch this adjustmentsilverGPX wrote:Why'd you touch the spring perch adjustment too?
You want height change, it's the one down the bottom of the coilover.
Re: Toby's nut
Nah you can move both together, it's like he threw his toys out of the pram and grabbed the thread with his stillsons and went to town lolPHIL069 wrote:This is crazy f**ked up, even for you Toby
Re: Toby's nut
No lol
Re: Toby's nut
So you stuffed up with even moar stupitity than I thoughtdestinationtoby wrote:PHIL069 wrote:This is crazy f**ked up, even for you Toby
No lol
Re: Toby's nut
Bought them second hand off some bitch (you know who you are) •_• advertised as "still new"
, upon delivery, all 4 were seized in the bottom part (height adjustment) never touched the springs, they were allready damaged. Managed to unseize 3 of the 4 and get the right height, last one wouldn't budge under any circumstances, so I got took the measurements to get it exactly where I wanted it and ended up being able to move it with some heat, a vice and stilsons.
Re: Toby's nut
Lesson learnt, don't buy 2nd hand sh*t.
Re: Toby's nut
Still no. Your trying too hard now phil, giveupPHIL069 wrote:So you stuffed up with even moar stupitity than I thoughtdestinationtoby wrote:PHIL069 wrote:This is crazy f**ked up, even for you Toby
No lol
Re: Toby's nut
Wow...
