In mother Russia, import owns all.Sahin wrote:You don't own import, import owns you
Rocker cover gasket
Re: Rocker cover gasket
- SchumieFan
what? since when?dstocks wrote:Nup, you have to order them separately.Complete gasket kit should come with two rocker cover gaskets.
(engine rebuild in 05 had them with)
Yeah, complete gasket kit includes both rocker cover gaskets.
Sorry, misunderstood. When I order MD309002 it is only a single gasket. You have to order 2 to get front and back. Wasnt referring to complete kit as that is not what he is after.
Oh right my bad!
Okay, so in looking to replace the gaskets, and plug seals soon.
I looked up Camskill, I have a contact, so could perhaps get slightly cheaper shipping (depends)
The set of 3 plug seals are
http://www.camskill.co.uk/products.php?show=64228
37.15gbp
The gasket is
http://www.camskill.co.uk/products.php?show=85232
14.95gbp
However, if I have non Mivec
http://www.camskill.co.uk/m3b0s9p59/MIT ... _Non_Mivec
19.99gbp WITH the plug seals.
WTF...
I have spent a fair bit of time searching, and cannot find the plug seals for Mivec to be any cheaper, or with a gasket kit, and they want 37.15 just for the plug seals???
EDIT: Meanwhile, in Japan Land
http://mitsubishi.epc-data.com/fto/de3a ... -head/746/
37.15gbp
The gasket is
14.95gbp
WTF...
http://www.camskill.co.uk/m3b0s9p5811/_ ... V6_EnginesAstron_Boy wrote: I have spent a fair bit of time searching, and cannot find the plug seals with a gasket kit.
I meant in comparison to the non mivec kit with the 3 plug seals and rocker gasket.
Oh, sorry, was just trying to helpAstron_Boy wrote:I meant in comparison to the non mivec kit with the 3 plug seals and rocker gasket.
All good.
Ended up going Amayama, cheaper in the end.
Those plug seals are a joke on camskill.
I believe payaya was saying that the plug seals were the same as a Magna and were only a couple bucks each from Mitsubishi Austalia.
Same as 6g74 by the research.
In the end, I need the rocker cover gasket, and not removing the cover twice, so...
