zuihoujueding wrote:From Astron_Boy:
Rear: DBA547 $100 each
DBA and RDA rotors
Re: DBA and RDA rotors
Now you are just confusing things. What do those numbers refer to and whats the comparison between them.
The numbers after the first 3 letters dictate the model.
The first 3 letters are the manufacturer.
So, DBA425 and RDA425 are the same.
Just the manufacturers are the difference.
DBA425S and RDA425S are slotted
I have emailed Brakes Direct and asked them if they will do a group buy. Waiting for a reply
Excellent!
Good timing, too!
Meanwhile, what's the difference between the regular ones and the "dark series"
- vipfto
Regular are either normal or sloyted
Dark are slotted and dimpled
Ah, ok cheers.
How much is the difference in brake pad wear between standard, slotted and slotted + dimpled?
- vipfto
Check their site for detailed info
Basically slotted helps disperse gases that build up between rotor and pad and effectively dimples should be better. But for the masses they really look good
- HeRo
Add me to the list. I will buy RDA front slotted/dimpled rotors.
Hopefully group buy will prevail
Add yourself!HeRo wrote:Add me to the list. I will buy RDA front slotted/dimpled rotors.
viewtopic.php?f=1&t=27846&start=20
