APEXi N1 Exhaust System
Anyone out there with this exhaust fitted?
What's the experience so far, any qualms?
Also, how loud is it compared to the stock exhaust? Do you recommend a silencer or resonator fitted with it as well?
Thanks!
Thanks!
- GPXXX
i've heard them on FTOs before, and believe me - either get a resonator or a silencer fitted. They are pretty LOUD! however with the silencer fitted, i believe they may get a little restrictive as you reach the top end (like mine) so if you want power with the hoise - leave the silencer out. Otherwise, they're easier to live with on a day-by-day drive...
...of course, you can't compare the noise & volume with the stock exhaust!
I've got videos of an FTO with Apex'i N1 and Kakimoto mufflers fitted so you can listen to how they sound like... Personally i reckon they sound horny... let me know if you're interested.
- FTO338
- GPXXX
they are all in all in MPEGS. Click below to see them:
(they're about 1.3MB each, so be patient...)
http://users.ncable.net.au/~mikey168/FT ... %2001.mpeg
http://users.ncable.net.au/~mikey168/FT ... %2002.mpeg
http://users.ncable.net.au/~mikey168/FT ... haust.mpeg
ENJOY
ENJOY
- FTO338
A'pex N1
i changed N1 muffler few mth ago, and it sounds OK
FTO with original muffler is also pretty loud than other car
and i noticed that air goes out more smothly and sorta quicker with bigger cat converter but it's damn expensive
- FTO338
Hey AJY11Q, hmmm i bet your nickname is the number plate 4 your FTO!!
Anyway u said bigger cat gave u sorta quicker! U done a dyno on it or just what u feel??? I haven't seen any good result from dyno or mag that said a bigger cat do anything 2 a VTEC YO!!!!!/Mivec engine, i've even seen a lost in kw with a bigger cat 2!!
So yeah let us know how it is sorta quicker.
Thanks for the replies peeps.
I think I will get a silencer anyways since it's removable and only $100 extra. Peace of mind more than anything.
I'm leaving the catalytic converter as stock since that was changed when the car was imported 3 years ago. Unless there is something wrong with it, I'm leaving that alone.
- GPXXX
dude, i run a silencer on mine (though' not an Apex N1 muffler) and just thought you should know - it can get quite restrictive at high rpm... So unless you drive like a granny most of the time (below 3500rpm), get a resonator instead- it'll be less loud but sounds better without the silencer.
My 2 c...
My 2 c...
Thanks for the advice 02NV.
I'm going to go ahead with the silencer though. Found out it's only $60 odd dollars extra. And it's easily removable as well, which is good. On the APEXi web site, it actually says on some cars, the silencer improved mid-range throttle response. I'm not sure what mid-RPM range would be so, I guess I'll have to experience it for myself.
Fingers crossed, hope it's all good though. Let youse know in a few weeks!!
oh~don't be serious with my commentFTO338 wrote:Hey AJY11Q, hmmm i bet your nickname is the number plate 4 your FTO!!
i never hook up my car on dyno so maybe i'm wrong
that's my feeling
but i definetely noticed better and smooth sound from underneath of my foot when i'm driving
- MattG
The FTO cat is pretty high flowing naturally, but there are many FTO owners in the UK who have fitted a cat by-pass to gain more power.
If you replace your exhaust system with a larger one and gain power, then replacing the cat with a slightly larger one (or removing it) should also help remove restrictions in the exhaust.
Having said that there is a point at which the exhaust is too big for the vehicle, but if you are just changing your exhaust to 2.25"or 2.5" and getting a cat to match then I don't think you should have too many problems.
M@
M@
The Data Recovery Experts
- GPXXX
rule of thumb - NA motors will always need some amount of back-pressure - how much backpressure you have will affect the driveability (torque & response), so too little and you will lose some torque in the low-range... 2.5" is prob the absolute max you can go if the car remains N/A, any larger and you will suffer response/driveability issues...
I dunno much about larger high-flowing cats improving HP, but my suspicion is that it only gives an enlarged flowpath to reduce backpressure (to compensate for small/large diameter exhaust piping) - don't hold me on that theory though!
Turbo'd engines however really hate backpressure, so the less you have on turbo'd motors the better (and more HP)...
