Help Neutral Light Flashing
Coffeboy
Post by Coffeboy »
Hi Guys,
Need Help, Im in Sydney, Hurstville.
Wanted to know if anyone knows what would or could be wrong with the car. Its starting to flash Neutral, and only goes in Second Gear and Third. Even in Tiptronic mode.
Any Advise would be great, I need it soo bad, Could some one be kind enough to call me and let me know, as i dont really have net access at the moment,
Call me on 0415 747 666
My name is William
Thanks Heaps
smorison
The Godfather
Post by smorison »
This means your gearbox oil is overheating normally, the tip ECU is set to start Neutral flashing when this happens (normally only happens to me when i'm on a freeway at high speed for long periods)
if you're unable to go beyond those gears sounds like you've mashed the gearbox pretty substantially.
