I did. I did a full timing belt / water pump / cam seals etc service on the donor motor. Also did clutch & gearbox rebuild. The sh*t that adds up, is the sh*t you don't think of, the unforseen requirements to weld up a clutch slave bracket, the need to fabricate up a new exhaust Y-pipe, the need to upgrade to harder rubber engine mounts, the brakes etc. It's a killer.Daniel2019 wrote:Which is also a previously-done conversion (6A13tt which is fairly known to us FTO folk - whereas Evo 8 is completely new territory)Bennoz wrote:I started with a 7 grand budget. Turned into 25 grand... and I'm only FWD.
Also, Ben, was a huge chunk of your labor done yourself? Didn't you also source most of your own parts or?
Shops will put a mark-up on any parts they supply usually.
EVO 8 conversion
Re: EVO 8 conversion
- c3rbera
In other words, don't f**king do it lol. I got quoted 3k just to have an alternator replaced, 12k won't cut it especially for unproven things like an 8 conversion.Bennoz wrote:I did. I did a full timing belt / water pump / cam seals etc service on the donor motor. Also did clutch & gearbox rebuild. The sh*t that adds up, is the sh*t you don't think of, the unforseen requirements to weld up a clutch slave bracket, the need to fabricate up a new exhaust Y-pipe, the need to upgrade to harder rubber engine mounts, the brakes etc. It's a killer.Daniel2019 wrote:Which is also a previously-done conversion (6A13tt which is fairly known to us FTO folk - whereas Evo 8 is completely new territory)Bennoz wrote:I started with a 7 grand budget. Turned into 25 grand... and I'm only FWD.
At least go with things from the same generation..
Or better yet, turbo the thing, you'd get by comfortably-ish with that budget from what I can grasp.
Manual '95 GPXsilverGPX wrote:Nice supra
Its a bitch of a job,but thats a rip. Its a couple of hours workIn other words, don't f**king do it lol. I got quoted 3k just to have an alternator replaced
Come on guys!
Why are we on such a role to demotivate this guy to do the conversion its highly possible!
Mate i think your best bet to acheive this conversion is to take everything off of the car, strip the loom out of it, doors skins, dash, interior so you know what you are working with give it a really good clean up.
Now because you have all the parts stripped out of it you can start selling what you dont need to pay for the evo conversion parts. You can sell off the engine, brakes, loom interior parts etc etc.
Probably your best bet is waiting on a good deal on your evo gear.
While your waiting you can start polishing up and cleaning all your engine bay ancillaries like your wiper motor and other interior items.
Looking forward to your build thread!
Goodluck.
Goodluck.
Turps is good for cleaning the body I hear.
Holy f**k hahahahahahahahahahahahahahahahahahahahahahahahhahahahahahaha
- Shhtuart
I just lost my sh*t
Got a good chuckle out of that
- c3rbera
+50Vectose wrote: Turps is good for cleaning the body I hear.
- Kashikhan55
thanks buddy, but almost everyone is claiming its not going to work right so now im confused if i should even put money on it.silverGPX wrote:Come on guys!
Goodluck.
i still will go ahead with conversion but now not sure if evo 8s the right choice.
maybe galant might have to cut it
- rock_it
Anything can be done if you throw enough cash at it. Most people haven't done it, based on the cost.. I have seen 1 FTO/Evo conversion in the flesh, and most of the work was done by the owner and his Son ... With some mechanical help ...Kashikhan55 wrote:thanks buddy, but almost everyone is claiming its not going to work right so now im confused if i should even put money on it.silverGPX wrote:Come on guys!
Goodluck.
But given the expense they put in to it, they were not really in the sharing mood too much. Which I can understand...
- Kashikhan55
4g63t how about this engine? still awd but from similar generation as GPX with enough power.
would this be possible and approx how much cost?
- rock_it
Kashikhan55 wrote:4g63t how about this engine? still awd but from similar generation as GPX with enough power.
My advice.. Take your FTO to Meek, and ask them for a quote. These guys do the conversion to Lancers and will be the best people you could talk with...
Alternator is easy?
Take wheel off, loosen belt tensioners, remove belts, remove top engine mount, jack up motor, remove alternator.
Something I'm missing? 1 man could do it about half hour each way. 2 of us had the car back together in under 20 minutes once I got my alternator back from rebuild...
The date of the last post in this thread?Vyktym wrote:Something I'm missing?
- bjk
- Totes
This guy.Daniel2019 wrote:The date of the last post in this thread?Vyktym wrote:Something I'm missing?
You and your fking mates
- bjk
- Totes
Wut.Daniel2019 wrote:You and your fking mates
