Removing the amp system from the FTO in plans for a modification in the making.
Included.
Response Precision (Jaycar) 4x100 amplifier.
Positive lead, enough to run from battery to under the parcel shelf. with fuse block and fuse.
Ground lead, had it bolted under the rear seat.
40A noise filter
2x RCA leads (L+R x2)
Remote trigger wire to run to headunit.
I also have a Pioneer headunit with the ipod lead which I could also include at an extra price.
Price.... well, if there is interest for it I will look around for the average and go better, otherwise make me an offer and I'll consider.
Pictures on request, if you search in the audio threads you'll find the pictures of the gear.
(This is in the means of being removed, not all of it currently is.)
EOI: 4x100 Amp kit.
