Hi, Please, Please please can anyone help. 1996 gpx mivec, great when cold, the hotter it gets, or longer you drive it, 30km or so it starts trying to cut out at 7000rpm+ keep driving and it does it at lower revs, untill it does it at 2000rpm. NO one in this place knows what is causing it. it doesn't compleatly stop but tries too. you take your foot of or up the gears and when the revs drop its ok. no loss of power untill this happens. just spent £1100 on it, now this.
has anyone had the same problem, HOW DID YOU SOLVE IT.
oh yes, No fault codes.
ps this site is great,
another sad pom looking for help
- puppy
- DaveO
- Apothus
- aza013
- NSW Coordinator
- I8A4RE
- QLD Coordinator
aza wrote:have you tryed doing an ECU check for codes ?
puppy wrote:oh yes, No fault codes.
Ok need some info buddy, when you say cutting out, do you mean total power loss as if the engine was off or does splutter?
As dave asked is it auto?
- aza013
- NSW Coordinator
- manofwood
- aza013
- NSW Coordinator
I dont know if this could make a difference, but I had my overflow bottle line clog which caused a vacuum in the water circulation and was causing the radiator pipes to collapse when the engine warmed up. Not sure how this could cause power loss, but it would took a while to build up a decent vacuum. Worth a check though. Just take the radiator cap off and disconnect the pipe from the overflow and blow through it to make sure it isnt clogged.
