The Suspension Thread
AJ
Post by AJ »
Cheers fro that. Would pedders be able to identify all the bushes that need replacing? Reading this thread, it looks like there are loads. And what material do I get them in? With the strut tops, do I go for Tien adjustables? Should I replace shocks too? And droplinks, do I get the kit that Bennos got in this thread too? Would they work on my almost stock set up? Then there's sway bars...
Ben, what's that thing I've seen you change on Kaz's white FTO? The part that runs between the 2 front wheels with boots on either ends?
Hey mate, my recommendation for a hot street setup would be the following:
Shocks - 4 x KYB Gas
Part numbers; Front L: 334154 Front R: 334155 Rears: 341140
Approx $440
Ok, front bushes are as follows, I would replace all 3 types with the below listed Superflex polyurethane type:
SPF1160 Front Control Arm - Inner Front Bushing
Very common for it to go - stock unit is a one peice rubber unit with steel sleeve. Is replaced by 2 of the part numbers mentioned above with new sleeve.
SPF1500 Front Control Arm Lower - Rear Bushing
If front control arm bushes are done - this one must be done using the same density material. Available in both stock size & positive castor type. The superflex type only give 0.5 degrees positive castor. Where as the Whiteline ones give 1.0 degrees. Part number KCA317A
Note - you will have to get these done at a workshop as the factory rubbers are press fit & you need a 10 tonne press to get them off, so factor in some labour cost.
SPF1344 Front Sway Bar Mount To Chassis Bushing (16mm)
Places to Purchase:
Bursons Automotive - http://www.burson.com.au/allstores/Stor ... th%20Wales
Fulcrum - http://www.fulcrumsuspensions.com.au/superpro.html
Your crunchy noise is your front droplinks. Best (& cheapest) way to get them is through Camskill in the UK:
http://www.camskill.co.uk/products.php?plid=m3b0s10p151
The part your reffering to on Kaz's car was a strut brace. I'd recommend getting one of them too. You can get them off eBay.
Tein top mounts you will be able to get from Fulcrum (listed above)
From memory you've already got lowered springs, so it will be just a matter of pulling your old struts out, pulling the springs off them & then re-assembling on the new shock & with the Tein top mounts on the front.
mr-charisma
Post by mr-charisma »
If you price the bushes at supercheap / autobarn & they're cheaper than burson's they will beat it by a further 5-10% .. so it makes it even cheaper than sourcing directly from Fulcrum..
Funny, the guy at my local Burson's said he'd do the same thing with the Supercheap prices I already had :lol:
AJ
Post by AJ »
Thanks very much for the tips guys! You've saved me a lot of messing about. Now, just have to wait for tax time :D
Edit: Hey Ben, no it's not a strut brace that I'm on about. It was under the front of the car and was about a 6 c**t job on the first DIY day and you replaced the same part at dstocks on the purple FTO too.
I think you are talking about the CV's / drive shafts.
AJ
Post by AJ »
Yes Aza, that's it. How do I know if they are gone?
you will get a click/clunking sound when you turne it will get faster as you go faster.
AJ
Post by AJ »
Ah, ok, not getting that, thanks God.
They shouldnt really get f&*ked as long as the boot hasnt split and let all the grease out
AJ
Post by AJ »
Hey Ben,
You said Places to Purchase:
Which parts would I be looking to get from each place?
Thanks.
mr-charisma
AJ wrote:Hey Ben,
Thanks.
They're just your options .. buy as many or as few parts from each place as you'd like ;)
AJ
Post by AJ »
Places to Purchase:
This site only gives store addresses, not product range so what would I be looking for when I go or ask for a price?
mr-charisma
You'll have to grab the product numbers from here;
http://203.31.191.243/fulcrumCat/
Depends if you want to replace all the bushes, or just the worn ones as to what parts to replace.
I replaced all except a couple.. I have some spare bushes left over if you want them for cheap.. Ill get part numbers when I get home..
AJ
Post by AJ »
Yeah, that'd be good. Can you PM me the details?
So Bursons Automotive just sells bushes? Where's best to get struts?
mr-charisma
AJ wrote:Yeah, that'd be good. Can you PM me the details?
Burson's is like Supercheap / Autobarn, but they have better prices & will beat competitor's pricing.
They should be able to source the struts as well, but RPW has a pretty good price on them. or try contacting a suspension wholesaler..
Gholdwayne
Post by Gholdwayne »
Hey guys i wanted to install strut braces on my fto, is it ok to buy the ones that are on the net that is supposedly for the fto ? if yes, whats a good shop/online store ?
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
arctan
Post by arctan »
Gholdwayne wrote:Hey guys i wanted to install strut braces on my fto, is it ok to buy the ones that are on the net that is supposedly for the fto ? if yes, whats a good shop/online store ?
get the cusco ones ;)
I'm thinking about getting one
mr-charisma
Yeah, it's ok to buy the no name brand ones .. they are worse quality though & susceptible to bending .. mostly at the bracket, but they still do the job for the most part
If you want quality over price, then go for whiteline or Cusco brand .. I've tried the ebay ones vs whiteline & now vs cusco & the ebay no-name ones do give a noticeable improvement, but the other give a bit more noticeable improvement again
whiteline are;
www.whiteline.com.au
Gholdwayne
ok sweet, ill go for whiteline / cusco..
because i care for this car and i want quality :P
97 GPX Icelle Blue
FTO[For The Orgasm]
