Yeah, a lot smoother and sounds great tooI bet you can feel the difference thou!
It is only half done admittedly, i still need to do the intake from the bumper. However there is a carbon fibre heat shield around the cone itself which blocks out a fair bit of heat from the engine.Looks good but on the other hand, that just look like sucking hot air to me
apparently, its discontinued...Than an ARC intake pipe. Available from www.perfectrun.com.au. Not cheap!
Mate if your filter is not sealed you will most definately have decreased power at low speeds.rock_it wrote:Came with the car ... Sorry ...
I saw one of the FTO's in the UK with the same one ... Saw his car on cardomain.com ....
Seems to work fine ... all the wheel arch plastic and stuff is removed, and I am going to run some pipe up from the bumper (where the fog lights are) straight to the filter to get more cold air going up ...
I think the results of it really do speak for themselves ... Just with that and an exhaust had the car putting out 111kw @ the wheels ...
spot on.payaya wrote:Mate if your filter is not sealed you will most definately have decreased power at low speeds.rock_it wrote:Came with the car ... Sorry ...
A sealed unit will suck air from the outside, your unit even with a air intake will mostly be sucking air from your hot engine. Imagine your car taking off from idle. No cold air as vehicle is not moving, causing hot air to be sucked into the intake. If you make an intake with even a small bend in it, it would be deemed useless. Hold a peice of curved pipe in front of a fan or outside a window. Stuff all air, and considering how much air the engine needs, you may as well not have it.
You may have produced higher results on the dyno, because you have this massive fan blowing onto your engine, do you have this luxury in real life? No, so unless your sealed, your car would be producing less power with the pod filter.
